Time stamp bizarre issue
I'm using a PXI-6220 to acquire continous data synchronized with an external pulse.
System acquire data at the rate of the external pulse.
When a disconnect the external pulse input, data stop acquiring which is normal. When i reconnect the external timming source, data continues to acquire.
The problem is time stamp. If data stop acquiring 5 secondes so the time there were no timming source, the time stamp is late and give the next time increment related to the last time stamp acquired before it stop!?!?
I expected to get the actual time stamp after reconnecting the source...
Is i'm missing something?
(2,967 Views)
Hi GPGPR,
The timestamp is according to the DAQmx read, hence when the sample clock stops, the chart and/or graph stop as well. If it is just your signal that stops, then a waveform chart will continue to graph, but it will be a blank signal until your signal returns. If it has to be your sample clock source which stops, than the only way to get a true time is to do this in software using the ‘get date/time in seconds.VI’. A typical specification is that the sample clock has to be a continuous and free-running clock for just this reason.
David L.
Systems Engineering
(2,950 Views)
