Timestamp is automatically rounded (or jumps)
Sorry, wrong forum.
Posted to http://forums.ni.com/ni/board/message?board.id=170&thread.id=423063
Hi.  For some reason, in the attached VI, the timestamp that is generated is always rounded to the nearest 0.15625 seconds.  It's an odd value to be rounding to, especially when it shouldn't be rounding at all. 🙂  The attached zip file has the main VI with two subVIs (which I don't think are involved in this, but which are referenced from the main VI) along with a data file where the first column is the timestamps that are generated.
If it's relevant, I'm using the USB-6251 DAQ board.
Thanks!
Jeremy
Message Edited by mets501 on 07-10-2009 05:01 PM
Message 1 of 1
(2,759 Views)
