To draw a potential color map
I want to make potential color map of multi data.
Forexample I have 32data.And divide a square canvas 4*8 to paint.After that,make color map in obedience to the size of data(like small data(white)--middle(blue)--big(red)).1data is painted one cell in divided canvas.
I use LabWindows/CVI5.5.Do you have good way to make that? And what should I use commands in libralies?
(2,841 Views)
You could try using an Intensity Graph. This has a ColorMapArray that you can use to assign certain colors to certain values, and every value in between gets assigned a gradient automatically. All you would have to do is create your Z array, which is a 2d array mapping of the graph control. To use this, call the function PlotIntensity on a waveform graph control. Hope this helps!
Jeremy L.
(2,833 Views)
