Tri Axial Accelrometer to be used with NI 9234
I am trying to find a good small size tri axial accelerometer to be used with NI 9234.  I would most appreciate any suggetions.
(3,364 Views)
What is good?
Mounting?
Range?
DC?
Price?
Temperature range?
Application?
Quite small and cheap (sample for free;) ) are MEMS from ST/Freescale/AD ...
B&K(4326A / 4321) , PCB or Kistler (8290 / 8763) is another class
Some more requirements are helpful...
Greetings from Germany
Henrik
LV since v3.1
(3,351 Views)
Thanks.  My application involves measuring vibration due to a high speed (10000 rpm) hydraulic motor.  I am planning to attach 2 tri axial accelerometers on both ports of the motor. It does not have to be cheap, but it must be suited for my application.  Any suggestion is much appreciated.  Thanks
(3,346 Views)
Hi Sunnyabc,
We have the sensor advisor available online from our website; however, I recommend contacting an acclerometer company to discuss your application to ensure all of your needs are met.  You will need to ensure that you are under the 19V compliance voltage for the NI 9234.  Exceeding the compliance voltage does not damage the card but you will not read values above that level.  The compliance voltage may vary from transducer to transducer.  See this knowledge base article to learn more about calculating this value.  Good luck!
h_baker
(3,335 Views)
