Trigger an analog measurement with a digital output
With a USB-6341 and LabVIEW 2010, I have been unable to set up a triggered analog capture with the trigger being PFI 15 on Port 2 and the source for the trigger being an output on Port 0 (the two pins are tied together on the PCB).
The resulting output array has zero elements.
I have attached the VI and its sub-VI for review.
Thanks in advance for any assistance,
Jeff
(2,877 Views)
Never mind.  I figured it out.  Partially a hardware error, partially a setup error.
Jeff
(2,864 Views)
