Triggering a task using PFI on a PCI-6221 (37-pin) board
Hello everybody,
I need hardware triggered acquisition using the PCI-6221 (37-pin) board. In LabView, I used simple program (see attachement): in a DAQ assistent, the task triggering is set to PFI 7. However, bringing a pulse to PFI7 does not trig the acquisition and I get time-out error.
When I test the same, but using the standard PCI-6221 board (i.e. 68-pin), everything works fine.
Do I need to do some extra configuration for PFI when I am using the 37-pin board? (Note: the same pin is assigned to PFI7 and digital line P1.7).
Thank you.
Jiri
P.S.:  I am using LabView 8.0, NI-DAQmx 8.7.1 and Windows XP Proffesional.
(3,256 Views)
Accepted by topic author Jiri_2
Problem was curious but it is solved now:
 - NI-DAQmx actually was not 8.7.1, but 8.0.0; I updated it (but it was still not working)
 - I replaced virtual channels by corresponding physical channels; it started to work
 - I replaced back the physical channels by virtual one, and it is still working 🙂
It seems there is some bug somewhere in NI-DAQ.
Jiri
(3,251 Views)
