Triggering
I am having NI USB 6008. With this how can i Generate a Trigger output in the range of 10us... Is there any to generate Trigger output in my NI USB 6008????
(4,158 Views)
The digital outputs of the USB-6008 are software timed. The fastest you can change the outputs is on the order of 100 Hz. So, No, you cannot get anywhere close to a10 us pulse with that device.
Lynn
(4,136 Views)
