Trouble in the configuration of a PCI-6013
Hi:
I´m triying to get the MAX to recognize my PCI-6013 but i haven´t been able to get the DAQ board configured. I installed the package included with the board that contains LabVIEW 6.01 evaluation software and NI-DAQ 6.9.Of7 repeatedly, and then installed the board in a pci slot for several times. WindowsXP recognizes new hardware but when i try to install it no driver is found. I tried it whith the NI-DAQ 7.0 and the board got configured, but when i run a program i developed with the same board in another pc (and it worked perfectly) y get a 10001 error, something about wrong string orther or something like that. I thouth that maybe it had to do with the wrong channel definition (i did it as virtual channels, for an analog
input and 8 analog I/O). Well, i would like to get the sistem going with the NI-DAQ 6.9.Of7 since it worked in the past in another Pc ,or some hint in why i get that error working with the NI-DAQ 7.0. I would really apreciate any help, and thank you in advance, it´s nice to be able to rely in someone else with more knowledge and that is willing to help the others. Thank you again.
(3,146 Views)
I am not quite sure why the disk which shipped with your PCI-6013 included version 6.9.0f7. The PCI-6013 is one of our newer boards, and as such, is only supported by NI-DAQ 6.9.3 or Traditional NI-DAQ 7.0. These are the only two versions of the driver which will support this board.
Traditional NI-DAQ 7.0 and NI-DAQ 6.9.3 are completely compatible. The VIs which you will use in LabVIEW to program your PCI-6013 are the same. Both of these drivers are available for free download from our web site.
As for the -10001 error you are receiving, usually this has to do with an error in the channel string applied. Please see the following Knowledge Base article on our website for more information on this error.
How Do I Handle the DAQ -10001 Error?
http:/
/digital.ni.com/public.nsf/websearch/42643645D554D15986256A250054ACEB?OpenDocument
Justin Britten
(3,146 Views)
What is the link for the windows XP driver? I can't find driver downloads on the NI site.
(962 Views)
The drivers I needed were in NI-DAQmx version 15.5.1
(946 Views)
See: https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288253
(922 Views)
