Trouble linking my USB-6009 to matlab.
I an having trouble to make my version of Matlab recognise the USB-6009
My configuration
Windows 7 enterprise x64
Matlab r2011b x64 with daq toolbox
When I try to launch the interactive session  I get the following error message:
>>session=daq.createSession('ni')
>>"The vendor 'ni' is not known. Use 'daq.getVendors()' for a list of vendors.
Next step:
>> daq.getVendors()
>>Data acquisition vendor 'National Instruments':
      FullName: 'National Instruments'
AdaptorVersion: '3.0 (R2011b)'
 DriverVersion: 'unknown'
 IsOperational: false
Warning: Diagnostic Information from vendor: NI: There was a driver error while
loading the MEX file to communicate with National Instruments hardware.
It is possible that the NI-DAQmx driver is not installed or is older than
the required minimum version of '9.1'.
Additional information:
'Invalid MEX-file 'C:\Program Files\MATLAB\R2011b\toolbox\daq\daq\+daq\+ni\private\mexNIDAQmx.mexw64': The specified module could not
be found.'
I used dependency walker and found missing DLLs
My troubleshooting steps:
  1. Uninstall and re-install USB6009 with the latest driver and do all updates
  2. Use dependency walker on Matlab
These DLL seem to be missing
NICAIU.DLL
API-MS-WIN-APPMODEL-RUNTIME-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ERROR-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
API-MS-WIN-SHCORE-SCALING-L1-1-1.DLL
DCOMP.DLL
My preliminary conclusion is that there is a problem with the driver installation. Could you advise me which one could work better?
I am out of ideas.
Best regards.
(7,626 Views)
What is the exact driver and version you installed? The DAQmx driver also installs Measurement and Automation Explorer on your desktop. Does that detect the 6009?
(7,619 Views)
I installed the NIDAQ MXBASE 15.0 driver and updates.
I forgot to mention that I checked and the device seemed to be recognized although the interface seemed a bit different from our XP computers
Does this help?
(7,612 Views)
Accepted by topic author Sabria
You installed the wrong driver. The base driver is primarily for Linux and/or the Mac. You need the full version of DAQmx.
http://www.ni.com/download/ni-daqmx-15.1.1/5665/en/
(7,605 Views)
Super noob mistake but it is now recognized. Thank you for your fast support!
(7,595 Views)
