06-21-2012 04:24 PM
The device is not showing up in Measurement & Automation. Any help will be appreciated! Thanks!
06-22-2012 11:36 AM
HI Astockto,
This is Marcus from Application Engineering. Could I get a little bit more information about your set up such as the operating system of the computer, 32 or 64 bit, the current versions of any drivers you may have, and if you are using LabVIEW the revision that you are using?
If you go into device manager on your computer are you able to locate this device?
Marcus
