Troubleshooting a NI-DAQ driver update problem
I am having trouble with an updrade to NI-DAq 6.9.3. I was having a problem with my setup earlier and the NI consultant told me the best thing to do was to unistall the drivers for NI-DAQ and to upgrade to the newest version. I did so, and now my LabVIEW VI's wont work i get an error that reads. Code Interface Node has no code to execute. Pop up on it and select Load Object Code...then select the object code file (.lsb)
If i could get some help on this problem that would be great
Gregg
(2,782 Views)
Gregg,
It appears that the NI-DAQ 6.9.3 support for your version of LabVIEW was not successfully installed. Did you download NI-DAQ 6.9.3? Did you download and install the LabVIEW installation component for the version of LabVIEW you are using?
Spencer S.
(2,782 Views)
I'm having the same problem with LV 6.1 using NT4.
Old VI's no longer run after upgrading to DAQ6.9.3. It seems to be machine specific, maybe dependent on system configuration.
This seems drastic but we have had to remove all NI software, run regclean to clean NT registers of any redundant links, reinstall NT SP6 and reinstall LV 6.1.
Leave DAQ at version 6.9.2.
Having encountered this problem any attempt to reinstall DAQ 6.9.3 at this moment in time results in lost links to Daq32, DLL's and CIN. To date all attempts to relink the CIN functions and paths fail when DAQ6.9.3 is installed.
Stay with 6.9.2 and watch this space.
(2,782 Views)
