Troubleshotting my PXI-5922 module?
I am setting up my PXI chassis. I believe I have installed my MXI-4 card and it is recognized. I have plugged in the PXI-5922 card but the "Active" LED is off which I guess assuems it is not working properly. I have not been able to onfigure this device in MAX. hOW DO i TROUBLE SHOOT?
(2,878 Views)
Hi boniean,
The Active LED on all PXI Modular Instruments should only come ON when the module is actually running. On the other hand, if the Access LED is not ON, this is indication that the module may not be functioning properly. More information on the front panel LEDs and their status codes be found in the NI High-Speed Digitizers Help.
Does the Access LED turn ON?
Do you see your PXI-5922 in your Windows Device Manager?
Do you have the NI-Scope drivers installed? If so, could you tell me which version you are using?
S_Hong
(2,865 Views)
