Truncate a float number with a desired decimal limit
I would like to truncate a float number 1234. 056789 back to float number but with a desired fraction as the following:
1.  numb = truncate(1234. 056789, 3)  ---> numb = 1234.056
2.  numb = truncate(1234. 056789, 5)  ---> numb = 1234.05678
I did try:
float math_truncate(float numb, int n_trunc)
      int   i, n = pow(10,n_trunc);
      double num;
      i = (int)(numb * n);
      num = i/(n * 1.0);
     return (float)num;
Before return I have:
Case #1: num = 1234.056000000 ... after return, I have 1234.056107
Case #2: num = 1234.056780000 ... after return, I have 1234.05678107
Note1: I did try other methods, but the results are not as #1 & #2 ... always get some after the desired decimal point
Note2: The TruncateRealNumber (number) only truncate all fraction part ... num = 1234.00000)
*) Anyone can help? Smiley Sad
(3,018 Views)
This is a duplicate post.  See this thread.
Pat P.
Software Engineer
(2,996 Views)
