Trying to Read Load Cell w/ USB-6251
Alright, I attempted the tasks in M&AE with the same results. Differentially and ground referenced produced no changes. I pulled up to 10,000 lbs with no change in output voltage.
I attached a screen shot during RSE. It looked the same as differentially.
Message 11 of 12
(795 Views)
It appears as though you are using a regular voltage task.  I would try using a Custom Voltage with Excitation task.  How do I Configure a Load Cell in MAX? will help you get started.
Lynn
Senior Systems Engineer
Message 12 of 12
(780 Views)
