Trying to configure AT-MIO-16E-10 Daq card on Windows NT system using NI DAQ 6.1
Trying to configure AT-MIO-16E-10 Daq card on Windows NT system using NI DAQ 6.1. When I go to add new device in DAQ configuration wizard,card does not show up in List. How do I configure it?
(2,569 Views)
Greetings,
Your AT-MIO-16E-10 is a Plug and Play device, so you will not need to manually add it in the DAQ Configuration Wizard. There could be a couple of reasons why it is not currently present. If you installed the board in the computer before you installed NI-DAQ, you should uninstall the board, uninstall NI-DAQ, reinstall NI-DAQ, and then reinstall the board. Furthermore, your board is supported by our most recent version of NI-DAQ (6.9.3), so if you are not using version 6.1 for a reason, I would suggest installing version 6.9.3. It is available for download from the following location:
NI-DAQ Version 6.9.3 for Windows 2000/95/98/ME/
NT/XP
If this is not the solution to your problem, you may not have ISAPNP drivers installed. Below is a link with information regarding this situation:
Troubleshooting Plug and Play Devices for Windows NT 4.0
Good luck with your application.
Spencer S.
(2,569 Views)
