03-19-2008 10:56 PM
03-20-2008 07:13 AM
03-20-2008 10:49 AM
07-14-2011 02:51 PM
I'm new to Lab View and its hardware. I need to control 2 Solid state relays to turn on/off voltage for a device. Can someone help me with its setup and sample vi's? Like I said I'm new and need a head start configuring vi's and programming. I have an USB NI-9263 4 channel output device. My relays are made by GrayHill model 70-ODC5. I also have a 12~15 volt regulated power supply.
Also I need help controlling voltage levels without a programable power supply. Basically 1.5V, 1.4V, 1.3V, 1.2V, 1.1V, 1.0V, 0.9V.........decenting pattern. to achive this what do I have to do? Please provide me all the options. thanks
07-18-2011 02:13 PM
There are a few things to consider if you want to control relays:
(1) If the relay takes a digital TTL signal (5V, 0V), then you can use digital output. You can find examples of this here: LabVIEW » Help Menu » Find Examples... » Browse Tab » Hardware Input and Output » DAQmx » Digital Generation. The Write Dig Chan.vi is a good place to start to write a High (5V) or Low(0V) to a digital port.
(2) If you would like to output random DC Voltage values like 1.5V,1.5V, 1.4V, 1.3V, then you will want to use analog generation and output a DC value. Checkout the Analog Generation section of the Example Finder (location above) for Analog Generation examples. Additionally, the example below should output voltage values like you want:
Generate DC Voltage - Software Update
Aaron
