Turning off the ni pxi-1042Q before shutting down the computer, it freezes the computer.
I have NI PXI-1042Q chasis also have PXI-6255 and 6254 cards. The device connected to PC via fiber cable. When turn off NI before shutting down the computer, it freezes the computer. But, if shutting down the computer before turn off the device, there is no problem. Even though I tried it on three different computers (Windows 10), the result is the same. So if I turn off the computer first it works without issue. How I can fix this ?
Thanks.
(1,109 Views)
There is no way to fix this, this is expected behaviour.
You have to imagine that the cards are mounted in your Windows System as they were in your PCI/PCIe slots.
So if you just pull out various PCI devices out of your computer it will end up in a system crash as well.
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(1,053 Views)
