Two-Signal Edge-Separation Measuremen and input
I am using that mode and the second signal coms from comparator max941.  Could you tell me if I need there a pull-up resistor to conect it to the  gate of the timer? Becouse it looks like the timer doesn,t see the edges.
(3,125 Views)
We need more details from your pb to help you : connections, card, soft ...
Wilfried.
(3,115 Views)
NI 6221 PCI with SCB68 and LabView 8.0 . The output of the MAX941 Iis connected to the gate of timer1.  The timer is working in Two-Signal Edge-Separation Measuremen mode.
(3,105 Views)
Hi Fazi,
You should be able to connect two TTL compatible signals to the gate and auxillary lines and measure the time between the two pulses.  Take a look at the article found here for more explanation on how you can use this type of task.  Do you have something connected to the to the Aux_line and source?  Are you using an external clock for the source?
I hope this helps,
Paul C.
(3,099 Views)
