Two channel analog output generation using NI USB 6221
Hi all,
              I am trying to generate two sinusoidal waveforms with a VI for USB 6221 which has two analog output channels. My aim is to generate two waveforms simultaneously and introducing phase difference between them. i used two different VI's to solve the problem but couldnt succeed, i am posting the VI's here. I can see only one output, is given by the card and i checked it with oscilloscope, and also after running the both VI's  for a while they show error. i think the problem is with triggering digital signal. Please help me out of this problem.
Visu
(3,190 Views)
Visu,
You need to create a single AO task that contains both channels.  Suggest you read the section in the DAQmx manual on the Task State Model.
(3,181 Views)
