ULx Pulse Train for MC 1808x
I'm attempting to generate a pulse train using the ULx drivers for MC-1808x daq device. I've confirmed this device has counter output terminals. Following the shipping example (.\LabVIEW 2021\examples\ULx\Counter\Generate Pulse.llb\ULx Gen Dig Pulse Train-Continuous.vi--image of source code below), I am unable to make this work. The driver calls look very much like DAQmx driver calls and I'm able to generate the pulse train as expected (additional image of implementation attached). I see a stark difference between the ULx shipping example and the DAQmx example--notably via DAQmx, you need to wire the output terminal post channel creation while via ULx this isn't even an option.
Has anyone ever successfully generated a pulse train with ULx and can provide some insight here?
(692 Views)
This board is for discussion on NI DAQ products.
For MCC DAQ, it is best to post your question on Measurement Computing (MCC) - Digilent Forum
https://tmesystems.net/
(687 Views)
