URGENT: DAQmx read did not run
i've got a problem. My program was running before (LV8.2) an now it hangs at Daqmx read (LV2011). I want to read some analog signals, three counters and one digital signal. At the last counter it hangs (attachement point 1). the VI DAQmx is not executed. The input parameters don't have the delivered parameters (attachment point 2). When I use the tdms log, I don't use the DAQmx read and it runs. But I need it the other way.
Tomorrow the program has to run. I'm searching for failure since yesterday.
LV2011
PCI-7340
PCIe-6320
Best Regards,
Andy
_____________________
PCI-7356@UMI7764; PCIe-6320@SCB-68; LV2011; Motion Assistant 2.7; NI Motion 8.3; DAQmx 9.4; Win7
(3,281 Views)
Hello andyLAB
It looks like there is a problem with the task cannel of the third counter input because the information is missing on the Front panel.
Unfortunately the print screen is too small to see, from where the task is coming from.
Try to debug your program step by step and found out where the error exactly happens.
It is also possible to post the program, so other members are able to test the program.
If the VI is too big, reduce it to a small VI how shows only the error.
(3,246 Views)
Hi guys,
I hope this isn't too late, but I beleive the problem is that LabVIEW only allocates up to 4 threads per execution system per priority (by default).  Calling into a .dll (such as nilvaiu.dll which is called within DAQmx functions) will reserve one of those threads.  I can see from your screenshot that 4 calls to DAQmx read are executing in parallel--with a timeout of -1 they will never return until you receive the desired amount of data.  During this time, all four of your available threads are occupied by these calls and your VI will appear unresponsive until the DAQmx calls return (in your case, only after 1000 samples become available).
If this is inded the problem, a quick fix is to increase the number of threads allowed per execution system per priority.  You can do this by running vi.lib\Utility\sysinfo.llb\threadconfig.vi.  The VI is a bit dated but should be able to get the job done, a restart of LV is required for the settings to take effect.
When you call into DAQmx Read, it will block until the timeout has been reached (-1 in your case) or the desired amount of data has been acquired (1000 samples in your case).  My personal preference is to avoid calling into DAQmx Read in situations when the data might not be immediately available (within 100 ms or so).  You can use DAQmx Events (Every N Samples Acquired) to trigger an event case which calls the read, or you could simply poll for Available Samples per Channel before reading.  I think modifying your code in this manner is a better long term solution to increasing the thread count, as you can guarantee that your interface remains responsive even while waiting for the acquired data.
Best Regards,
John Passiak
(3,227 Views)
