USB-502 Install
Trying to install USB-502LCD on Windows 7 platform. Can't get drivers to install correctly? Any ideas?
(4,407 Views)
I would suggest you go directly to MCC to check on the availabity of a windows 7 driver.
(4,395 Views)
This is the response that I received from an Applications Engineer from Measurement Computing (the company that makes this device and the software for it):
"Regrettably Measurement Computing has not migrated our software to work
with any of the Windows 7.0 versions (32 or 64 bit)"
 However, he went on to say that in informal tests, the latest version of the software (version 2.3) seemed to work correctly with Windows 7 32 bit.
-Christina
(4,390 Views)
Hey Silvasy,
It looks like I am about 3 months late to respond, but I have successfully installed the MCC USB-502 driver software on Windows 7. Did you ever get it working? Can you describe what error it's giving you?
Chris Delvizis
(4,229 Views)
