USB 6008 DAQ Scaling
I'm using a USB 6008 to read analogue voltage signals from a device I built. The task is set up with single ended reading with a range of + -10 volts. There is no scaling in the task or the block diagram but when I acquire the data to a TDMS file and view it, I get a load of PieceWisePolynomial scaling properties. I've attached the TDMS viewer to this post.
Does anybody know where this comes from because I can't explain it.
Thank you,
Donners
(3,325 Views)
Accepted by topic author Donners
The data is coming back as an unsigned integer between 0 and 32k from the ADC on the 6008.
The scale is converting that unsigned int to a floating point value between -10 and 10.
CTA, CLA, MTFBWY
(3,295 Views)
Thank you Snowpunter
Donners
(3,277 Views)
