Greetings!
I have a USB-6008 DAQ device, which I have been working with, strictly with the DIO capabilities of the card.
I am attempting to create some basic VI’s which will allow for simple programmatic “if / then” cases. I have attached the VI that I have (successfully) created to handle the output side of the programming. However, I am having a lot of trouble getting the similar effect with an input VI.
Does anyone know what I might be doing wrong? Would anyone be willing to modify / create a VI that does what I need? I simply want to be able to add a control to select which line I want to read, and an output containing a Boolean T/F.
On another subject, has anyone solved the problem with this device, pertaining to the sourcing on the Input end? Why is it set up like this? And how does one get around it?
Much appreciated,
Alexander S. McGee
Test Lab Co-op
Stryker, Instruments Division
www.stryker.com
Message Edited by magnasmific on 05-25-2005 03:37 PM
Alexander S. McGee
Test Lab Co-op
www.stryker.com
