USB 6008 analog output
i use NIDAQ USB 6008.
i have the problem with analog output when working with Simulink. the message apears "you must use PUTSAMPLE insted....", this problem is solved in script M-files, but with Simulink it stands.
How to set PUTSEMPL in Simulink model???
how to write c-file (sdaqao.c) for S-function?
is it possible to use 6008 with Real-Time Workshop? How to modify an existing drivers??
(2,960 Views)
Hello Vova,
Given that you're using a lot of third party software the National Instruments discussion forums may not be the best place to get the answers you're looking for.  However, if you have questions about the specifications of your USB-6008, or if you're concerned that it isn't operating correctly we can certainly troubleshoot that.  If you believe that you have an issue specifically with your hardware please reply back with details.
Have a great weekend!
Message Edited by Brooks_C on 03-21-2008 04:59 PM
Brooks
(2,926 Views)
