USB-6008 and linux (Mandriva)
Thank you for using National Instruments forums.
Is the example working when you specify another physical channel?
Can you run a test to see if the card is working (on another computer for instance or with another OS)?
I'm assuming you are using a USB 6008.
Thanks for your answers,
Regards
Guillaume H.
National Instruments France
Message 11 of 12
(891 Views)
Yes I am using NI USB 6008. I could solve the problem. It was the issue of the firmware installed by default in the device. I had to switch from DAQmx to DAQmx base and then it works.! 🙂
Rakhi
Message 12 of 12
(883 Views)
