USB 6008 mating connector
Does anyone know that manufacturer, part number, and a source for the mating connector to the ones on the USB-6008?
Message 1 of 11
(5,685 Views)
I would suggest using the USB-6008/6009 accesory kit.
Todd V
NI Prototyping Community
Message 2 of 11
(5,672 Views)
Thank you for the suggestion but I have an application in mind that requires a larger area than the prototyping kit provides.
Message 3 of 11
(5,669 Views)
I want to connect my own circuit board to the USB-6008 in a similar way to the prototyping accessory but a larger board.
Message 4 of 11
(5,666 Views)
The accessory kit that I was referring to isn't the prototyping kit.  It includes four connectors, two labels and a screw driver.  You can connect your circuit board directly to the connector.
Todd V
Message 5 of 11
(5,661 Views)
I was planning to have a board with the mating connector soldered directly to it much like the protyping  board. That is why I was inquiring about the connector.
Message 6 of 11
(5,646 Views)
To answer your question they are Phoenix Contacts Connectors. If it is a 16 pin connector then this is the mate.  1803714
Otherwise check with folks like Newark and do a search on that part to get to the correct catalog page.
Message 7 of 11
(5,620 Views)
The connector I am looking for is the one used on the USB-6000 Series Prototyping Accessory.
Message 8 of 11
(5,595 Views)
You may want to look at the OEM version of the USB6008 as well.  It is sold as just the PCB and it has a standard 34 pin, 0.100" connector.  I've used them in fixtures where I had a custom interface to the outside world built on a PCB. Then I had a simple ribbon cable jumper from my board to the 6008.
Message 9 of 11
(5,564 Views)
So you either want  1786543  or 1786080
one is straight one is right angle.
go to
http://www.phoenixcontact.com/usa_home
and enter the part numbers
Good luck buying less than quanties of 50 unless you can find a stocking distributor.  Allied Electronics carries the brand as do many others.
Can I have a cookie now. . . . . . How do I get myself sucked into this?
Message Edited by Tom Powers on 06-02-2010 09:33 AM
Message Edited by Tom Powers on 06-02-2010 09:37 AM
Message 10 of 11
(5,553 Views)
