USB 6008 relay switching speed? Delay through software?
I asume:
- you need to do the testing because there is a requirement.
- you need something like 1-2 ms timing resolution to make brownout/ power down tests on your products.
- with USB 6008 software timing jitter, relay timing jitter and bouncing.....   how do want to repeat a test (get the same result under the same conditions) if your switching condition is not stable?
you can have it : good, cheap and fast .... pick two 😉
One hint for a solution: have a look into the standards on how to perform such test.
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 12
(1,840 Views)
Its not meant to be used for compliance testing. Its meant to be used for prototyping tests. But its a long story.
Message 12 of 12
(1,833 Views)
