USB 6008 with Windows Embedded Standard 7
I'm trying to get our software to work on a new system based on Windows Embedded Standard 7. I'm having trouble getting the DAQmx installer to finish properly. All that we need is the device driver for the device - is there some way I can find just the inf and sys files needed to install the device?
(4,884 Views)
I managed to get it working. I grabbed the files specifically mentioned by the inf file, then ran a static dependency analysis on the files. The list below shows everything I used. We haven't fully tested to make sure everything works like it should, but the device installs and our software talks to it.
niemwv.inf
niemrkw.sys
NIUSB71D60200.bin
nisdigkw.sys
niem.cat
niemrk.dll
nindciu.dll
nisdigk.dll
nicdrk.dll
nidmxfk.dll
nifslk.dll
nimsdrk.dll
nimstsk.dll
nimxpk.dll
msvcr71.dll
usb6xxxk.dll
nimdbgk.dll
nimxdfk.dll
niorbk.dll
nimru2k.dll
nidimk.dll
nipalk.sys
(4,854 Views)
Hi Jon,
Thanks for posting back and letting us know your status and what you did to get it working!
Matt
(4,849 Views)
Just another update...
I tried installing using just those files on a fresh install of WES7 and the device could not start. My current procedure that works, but is messy, is:
Run NI-DAQmx installer, perform custom install. Install NI-DAQmx 9.2.1 and NI Measurement & Automation Explorer. (MAX was required - I couldn't deselect it) Click through the errors that come up for certain packages during the install.
Uninstall everything but NI-DAQmx (there are 4 other packages)
Copy the dll and sys files listed in my last post into both system32 and system32/drivers.
Reboot and plug in the USB-6008. Browse manually to the directory you copied the files from when installing the driver. It should install without any problems.
I tried putting just sys files in the drivers folder but it failed. I suspect that it is because many of the dlls are dependencies of nisdigkw.sys, which isn't ever properly installed. Performing the right steps to register the sys file and dlls would probably fix the issue.
(4,822 Views)
Sorry to dig up ancient posts, but I am trying to install NI-DAQmx Runtime 9.7.5 core on a machine running Windows Embedded Standard 7. Where did you find these files?
(4,106 Views)
I honestly don't recall - I think I may have unpackaged them from the packages on the install media, but they should also all be installed to system32 or system32/drivers if you do a complete installation on another system, and then you can copy them from there.
(4,075 Views)
Ah, that would make sense, I'll give it a try. Thank you very much.
(4,070 Views)
