‎09-20-2005 11:07 AM
‎09-20-2005 02:29 PM
‎09-20-2005 02:45 PM
Thank you so much for your reply. It has been very helpful. You said, "Using NI-DAQmx 7.5 you can get support for software-timed waveform generation." I am only a novice at LabVIEW and data acquisition in general. What did you mean by software-timed waveform generation? I have NI-DAQmx 7.5 downloaded and installed already. Also, you said, "Note that the spec for analog output on the USB 6008/9 is just 150 samples/second." Does this mean that I cannot generate a waveform that is more than 150 Hz?
‎09-20-2005 04:17 PM
‎09-20-2005 04:36 PM
‎09-20-2005 06:43 PM
