USB 6009 Multifunction I/O with dasylab 9
Can somebody explain me how to see this DAQ in dasylab 9.0. I installed Labview 8.6, and NiDAQmx 8.8. But still, i cannot see the device.
(3,407 Views)
Hi, Stjepan.
Are you able to see the USB-6009 in Windows Device Manager or in Measurement and Automation Explorer (MAX)?
Sara Lewandroski
Applications Engineer | National Instruments
(3,373 Views)
Yes, I see it in Device manager, but not in Dasylab. Also I can see it in all Labview and signal express and MAX. Thank you for help.
(3,350 Views)
Hi, Stjepan.
Where exactly are you trying to locate the device in Dasylab?  There is no list of devices that appear in Dasylab, like in MAX and Device Manager.  Dasylab calls tasks from MAX.  If MAX is opened before Dasylab, Dasylab will not be able to call tasks from MAX.  You must make certain to close MAX before opening Dasylab.
Sara Lewandroski
(3,330 Views)
