Thanks for the suggestions. After reinstalling all of the NI hardware drivers (took about 8 hours) the device seems to be working.
Do you (or anyone else) happen to know if it's OK to disconnect a USB cable to an NI device while Windows is running, and/or if an NI USB device is negatively affected by powering down the computer without shutting down Windows? In other words, can I treat these like normal plug and play USB devices or do they require special care?
Thanks again,
Britt
