USB-6210 - erratic reading
I am working on a simple temperature data logging with USB-6210. I am getting unstable temperature reading on my chart only on AI0, other 7 temperature channel is fine. The temperature temperature fluctuation on AI0 is as much as 40 C. on other channel it's only 2~3 C, which is fine.
Taking the measurement using multimeter from ground to AI0 showing consistent reading, No fluctuation. I tried other channel as well AI15 as such. same results. Anybody has explation?
Excuse my english
(3,168 Views)
try to connect your GND of your card with earth of your device with one resistor by be it fix
also what kind of temperature sensor you have?
(3,102 Views)
