USB-6211 Analog output won't go below 3.38V
Hi rfgarciar,
Is your board is failing the self calibration? If so, it more than likely needs to be sent in for repair.
http://www.ni.com/support/
Jayme W.
Message 11 of 14
(1,112 Views)
I'm having a problem that is the opposite of yours: when I put a signal into the channels that are scaled by 2, MAX shows the table of data values 2X the input for a range of 0 - 10 VDC; however, when I look at the data going into the graph the values are always maxed out at 10.6 whenever I go over 5 VDC! And this is verified by the probe tool. Your are having a lower limit problem and I am having a higher limit problem. What gives?
Message 12 of 14
(1,095 Views)
Oh! It is a new device. We bougth it one month ago.
Message 13 of 14
(1,078 Views)
Hi JaymeW
Yes, is falling the selfcalibration 😞
Message 14 of 14
(1,076 Views)
