USB 6211 measurement range
I'm curious about the USB 6211 DAQ Box's measurement range, and more specifically how it's set. In the handbook for the device a table of supported input ranges is listed here http://www.ni.com/pdf/manuals/371932f.pdf with the same information being repeated in the complete manua at section 4-3; however, in MAX and Labview the input range configuration is completely arbitrary! That is, I can enter whatever values I want into the maximum and minimum input ranges, as long as they aren't greater than 10V. Naturally I'm a bit skeptical that this steplessly variable configuration on the software side results in sensible hardware side changes. My questions are: do I have to stay one of these measurement ranges? What actually happens on the hardware side when I set the input range to something other than one of the recommended input ranges? If I set +/-250mV, is the output even sensible?
Thank you for your time and help,
Matthew Berwind
(4,095 Views)
Accepted by topic author metavektor
The DAQmx driver accept all range values, but will check against the hardware specified and give an error , a warning or simply adapt to next higher range that fit.
So after a configuration you can use the property node or the DAQmx vi to read back the actual range choosen by the driver.
Greetings from Germany
Henrik
LV since v3.1
(4,093 Views)
Vielen Dank für Ihre schnelle Rückmeldung!
Grüße aus dem Schwarzwald
(4,089 Views)
