USB-6211 w/ DAQmx
Greetings All,
Requesting if any user can verify that the DAQmx; Channel Properties Node; Filter; Window Averaging function is supported by the NI USB-6211 OEM board?
This functionality is critical for the planned app and need to know before ordering.
Thanks Group,
Chris
(3,852 Views)
Hi Chris,
No, it is not. AI.AveragingWinSize was added for a specific use case that requires some signal processing to be done in hardware: NI-DAQmx Hardware-Timed Single Point Support for Oversample Clock Timed Devices
For more general use, LabVIEW has a wide variety of signal processing VIs, such as for windowing, FFT spectrum (with window), etc.
Brad
Brad Keryan
NI R&D
(3,848 Views)
Thank you Brad_K, By 'no it is not' I assume you mean that it may not be what I need. You make this assertion although you do not know anything general or specific about my application needs :>( If I misunderstood your comment please correct me. That being said, it does appear that the function in question is suited for specific NI hardware w/ overclocking capabilities and functionality - generally PXI devices (as per write-up you provided). I have not used DAQmx that much and am somewhat confused as to what will 'work' with the basic functionality of the mx subroutines and specific setting alterations. I know I can 'filter' the functionality I see for installed hardware, but IMHO that hinders learning what the vi's can 'do'. I believe the zero-phase IIR filter may provide the particular smoothing we need, but results may vary so-to-speak. Thank you for your response, Chris
(3,834 Views)
Accepted by topic author bonnerupc
Hi Chris,
> By 'no it is not' I assume you mean that it may not be what I need. You make this assertion although you do not know anything general or specific about my application needs :smileyembarrassed:(
I wrote "No, it is not" as a reply to your question. I should have written, "No, the AI.AveragingWinSize property is not supported by the NI USB-6211 OEM board."
Brad
Brad Keryan
NI R&D
(3,826 Views)
