USB-6212 6212 - Analog Output Stops! Doesn't Happen with NI9263
Hi all,
I am using the Analog Output to play many sequential files through that are ~30 seconds long.  As I send them to to the DAQ, I also plot them at the same frequency on screen just for a visual reference (Obviously they aren't perfectly aligned, but that is fine for what I'm doing).
Here is a basic flow chart; note the 2 paralell tasks of plotting and sending to AO1:
[Open File 1] --> [Send through AO1] --> [Loop to the Next] --> [Open File 2] ---> [Send through AO2], etc. etc.
                         [Display on a Chart]                                                              [Display on a Chart]
I initially wrote this (very simple!) code for the NI9263 and it worked great.  Recently I acquired a NI 6212 (USB Module) and find that it doesn't work right!
It still opens and closes files just fine; the chart continues to update and show to me that I am indeed loading the next file in the set.  However, the DAQ stop outputting after just the first file.  I don't know why it is doing that.
I've tried the following permutations:
Windows 7 PC
Windows XP PC
NI9263 (I tried two different ones, both are fine!)
USB-6212
Labview 2011
Labview RunTime 2011
Even on an old Win XP PC, I can get the NI9263 to work just fine...
Some notes:
I'm outputting on AO1 using both the 9263 and the 6212.
I have a DAQmx task configured for N Samples, and set it to write the same number of samples in the file (2000 points per file, thus I have it set to n=2000), and set it to the correct frequency (100Hz)
Any help on why the 6212 stops outputting on the file file, but the 9263 just keeps going on?
(3,179 Views)
I just wanted to briefly ask if you are receiving any errors in either case.
Also, which chassis are you using the NI 9263 in?
Eric
(3,152 Views)
cDAQ 9172.
No errors are thrown in either case
(3,147 Views)
