USB-6212 Not Installing Correctly
I have a USB-6212 DAQ unit with DAQmx 8.6.1 and it will not install. It is shown in the Windows Device Manager under Data Acquistion Devices and is called a USB-621x Loader. The kb that describes starting a service does not apply because that service is running on the computer that the install is not working. What is the problem?
(2,420 Views)
I have a USB-6212 DAQ unit with DAQmx 8.6.1 and it will not install. It is shown in the Windows Device Manager under Data Acquistion Devices and is called a USB-621x Loader. The kb that describes starting a service does not apply because that service is running on the computer that the install is not working. What is the problem? snaptube for pc jiofi.local.html
(1,795 Views)
