USB-6215 DI ReadMultisamplePortByte rate is only 2kHz
I'm attempting to use the USB-6215 to determine the speed/direction of a fan using two optical sensors. I'm using the following code in a .NET library to take get 1000 samples from two lines and use the data from when the optical sensors are activated to determine speed/direction.
using (Task ctr0 = new Task())
  using (ctr0.DIChannels.CreateChannel("usb6215/port0/line1:2", "", ChannelLineGrouping.OneChannelForAllLines))
    ctr0.Stream.Timeout = 500;
    DigitalSingleChannelReader dReader = new DigitalSingleChannelReader(ctr0.Stream);
    try
      // Start the task
      ctr0.Start();
      byte[] results = dReader.ReadMultiSamplePortByte(1000);
      ctr0.Stop();
    catch (DaqException e)
      Console.WriteLine("DAQ Exception: " + e.Message);
// Analyze sample data and calculate speed/direction
This seems to work fine, except for one thing: the samples only appear to be taken at a rate of 2 kHz. This means that at some higher RPM's, the DAQ will sometimes miss one of the optical sensors being activated. According to the datasheet, the USB-6215 has a max sample rate of 250 kS/s, and looking through some other threads, this rate is divided by the number of channels you are sampling (ie, sampling two channels gives you a rate of 125 kS/s for each channel). My question is, why is my sample rate so low, and how can I sample at a faster rate?
(4,755 Views)
Accepted by aswanson08
The data sheet says that the rate you quote is for the analog input. It clearly states that the digital I/O is software timed and you are lucky to see 2kHz. The max with software timing is usually around 1kHz.
(4,749 Views)
Dennis,
Thanks for your reply! I do see now that I was looking at the sample rate listed for Analog Input. I must have missed the mention of DI/DO being software timed in the User Manual. It unfortunately doesn't seem to be listed in the data sheet. I may look into converting my measurement to an analog input to get the speed I need...
(4,738 Views)
