USB 6215 analog output problems with analog input and counter reading
Hi, I am using Labview 8.2 and trying to get one channel analog input and one counter reading, meanwhile one channel analog output based on the analog input.
I am using USB 6215.  It seems that I can get the analog input and counter reading o.k., but could not generate any analog output at 1000Hz.
The device does not support hardware sampling so I used continuous timing and sample clock.
Here are some screen shots.  Any suggestions on how to get the analog output work?
Thanks.
Fug101
(4,539 Views)
Hi Fug101,
Could you please post your code?
Jim Schwartz
(4,515 Views)
Hey,
Try changing DAQmx sampling in AO to conti. instead of finite and also set your AO to non-regeneration using DAQmx property node.
cheers
-Lab
(4,514 Views)
Code is attached.
Thanks.
(4,508 Views)
Thanks, how to set the property node? could not find out.
Could you please show an example.
Fug101
(4,506 Views)
I have attached a picture that will show you where to find the regeneration property node.
Jim Schwartz
(4,484 Views)
Jim,
Thanks.
It seems now it starts to work.  But here comes another issue.
The Analog ouput does not update in time (embedded in the while loop).
Also, when it works, there is a significant delay between the sign flip (controlling the motor direction) and the real action of motor -- about 1 second.
The question is, how do I update the AO channel instantly when the sign is flipped.
Best,
fug101
(4,451 Views)
