10-17-2006 08:27 AM
10-17-2006 09:45 AM
The USB-6218 has an aggregate sampling rate of 250 kS/s. This means that you can achieve this sampling rate if you have only one analog input channel in your task. If you are using multiple channels, the 250 kS/s maximum will be divided by the number of channels in your task.
For example: 250 kS/s divided by 15 channels will yield a maximum sample clock rate of 16.666 kS/s.
Using a moderately fast computer with USB 2.0, you should be able to sustain the maximum rate for analog input without any problems.
Sal
10-17-2006 09:47 AM
how does that compare to dual 6221's?
im unsure if they are aggregate and how the actual computer deals with 2 pci devices.
Thanks.
10-17-2006 09:54 AM
The PCI-6221 device also has a maximum aggregate sampling rate of 250 kS/s. This means that the 250 kS/s sampling rate is divided by the number of channels in the task.
I'm assuming that you needed two PCI-6221's because you have only 8 differential channels on a 6221. So you can have 8 differential channels on one 6221 and 7 channels on the other. 250 kS/s divided by 8 channels yields a maximum rate of 31.25 kS/s.
So, using two devices with an aggregate sampling rate of 250 kS/s will yield a higher maximum rate (for 15 channels) than only using one device with a maximum aggregate rate of 250 kS/s.
The computer treats each PCI-6221 as a separate data aquisition device. Each device has its own maximum rate and runs independently of the other. In fact, each of the two PCI-6221 devices must run in a separate NI-DAQmx task.
Sal
10-17-2006 09:58 AM
Thank you.
New question, what about EMI shielding? I will be placing the USB device right next to a very powerfull permanent magnet generator so it may be influenced by magnetic fields and strong currents nearby, not electrically, but physical location.
Is the plastic case an effective shield?
10-17-2006 10:18 AM
The USB-621x devices are housed in a plastic enclosure. They are certified as a Class A device for electromagnetic radiation immunity. More information about the electromagnetic compliance of the device can be found in the specifications.
The USB-6218 is designed to not be susceptible to noise in a typical office or lab environment. Although I haven't used one in the presence of a high electromagnetic field, I wouldn't be surprised if you did see noise on your measurements because of it.
We do offer the USB-6259 which is housed in a metal enclosure. That device will offer better shielding and may be preferable in your application.
Sal
On a side note.... I used to work at a high magnetic field laboratory. We always kept our measurement equipment in a separate room several feet away and behind shielding. These were pretty high fields. We'd all have to degauss our monitors after running it.
10-17-2006 11:15 AM
