USB 6218, Anybody have one yet?
Im going to be purchasing one of these today. Anyone used one yet? Thoughts? impressions?
I searched but this is the first 6218 post ever.
It states that it is 250K/s sec for one channel (aggregate)
What does this yield im im using 15 diff channels??
How does this compare with another one of my systems using dual 6221 M series cards?
(3,746 Views)
The USB-6218 has an aggregate sampling rate of 250 kS/s.  This means that you can achieve this sampling rate if you have only one analog input channel in your task.  If you are using multiple channels, the 250 kS/s maximum will be divided by the number of channels in your task.
For example:  250 kS/s divided by 15 channels will yield a maximum sample clock rate of 16.666 kS/s.
Using a moderately fast computer with USB 2.0, you should be able to sustain the maximum rate for analog input without any problems.
Sal
(3,738 Views)
how does that compare to dual 6221's?
im unsure if they are aggregate and how the actual computer deals with 2 pci devices.
Thanks.
(3,737 Views)
The PCI-6221 device also has a maximum aggregate sampling rate of 250 kS/s.  This means that the 250 kS/s sampling rate is divided by the number of channels in the task.
I'm assuming that you needed two PCI-6221's because you have only 8 differential channels on a 6221.  So you can have 8 differential channels on one 6221 and 7 channels on the other.  250 kS/s divided by 8 channels yields a maximum rate of 31.25 kS/s.
So, using two devices with an aggregate sampling rate of 250 kS/s will yield a higher maximum rate (for 15 channels) than only using one device with a maximum aggregate rate of 250 kS/s.
The computer treats each PCI-6221 as a separate data aquisition device.  Each device has its own maximum rate and runs independently of the other.  In fact, each of the two PCI-6221 devices must run in a separate NI-DAQmx task.
Sal
(3,732 Views)
Thank you.
New question, what about EMI shielding? I will be placing the USB device right next to a very powerfull permanent magnet generator so it may be influenced by magnetic fields and strong currents nearby, not electrically, but physical location.
Is the plastic case an effective shield?
(3,731 Views)
The USB-621x devices are housed in a plastic enclosure.  They are certified as a Class A device for electromagnetic radiation immunity.  More information about the electromagnetic compliance of the device can be found in the specifications.
The USB-6218 is designed to not be susceptible to noise in a typical office or lab environment.  Although I haven't used one in the presence of a high electromagnetic field, I wouldn't be surprised if you did see noise on your measurements because of it.
We do offer the USB-6259 which is housed in a metal enclosure.  That device will offer better shielding and may be preferable in your application.
Sal
On a side note.... I used to work at a high magnetic field laboratory.  We always kept our measurement equipment in a separate room several feet away and behind shielding.  These were pretty high fields.  We'd all have to degauss our monitors after running it.
(3,722 Views)
The biggest source of error may be the EMI generating voltages in all your signal wiring that is external to the USB device.
(3,714 Views)
