USB 6218 NOT recognized
Hello!
I need some help to understand (and maybe solve Smiley Wink ) a problem with a USB 6218 device.
In some of our test bed systems, for engine testing, we have NI USB 6218 devices for additional analog input.
After some monthes of normal activity, when i plug the usb 6218 into a specific computer, it isn't recognized correctly and it doesn't work anymore.
In Max it appears as shown in the attached picture.
  • The computer where the system is installed is a Win7 x64.
  • Tests were done with DAQmx drivers 9.6.2 and 14.0.
  • Different USB cables
  • Different 6218 devices
  • Different computers with the same software installed
  • Other USB device, like HD WebCams, are working properly.
Do someone had a similar problem? Any advice is very appreciated
Thank you very much for your help
Davide Galli
(7,253 Views)
So it is behaving similarly on another computer as well? Have you disconnected all signals to the board? If so I would suspect the device and call NI support for options.
(7,247 Views)
(7,225 Views)
Hi Davide,
did you try to change USB port. Do you have an USB Hub or a direct connection?
You can try with suggested steps.
http://digital.ni.com/public.nsf/allkb/2E02F8EC5D0197928625758C005FFD8D
If they don't work, you can try with a DAQmx repair. Or with a MAX "Reset COnfiguration Data" (Tools -> Reset Configuration Data)
Kind Regards.
Cla_CUP
NI ITLAY
(7,211 Views)
I checked the option and NI Device Loader is running and automatically lauched. I tried also to reboot the service but nothing changed.
I already tried "Reset Configuration Data" from Max without success.
Of course the test was made over different USB devices: front usb connectors and on a secondary PCI USB usb controller.
The test was done also with the USB-6218 without any connection.
Thank you for your help
(7,195 Views)
Did you try the USB ports on the back?
(7,182 Views)
Accepted by topic author Davide_Galli
I tried almost everything...
The solution was "FORMAT C:"
With a new installation of Windows  7 64 the problem disappeared!
Thank you for you help! 😉
(7,154 Views)
