USB-6218 as USB Firmware Downloader
I have a USB-6218 connected to a XP computer with DAQMX 9.5, for some reason the 6218 shows up as a USB Firmware Downloader in Device Manager under Data Acquisition Devices.
The device does not show up in MAX and the LED on the device if OFF.
I had this problem earlier I was able to fix this by uninstalling DAQMX9.5 and reinstalling DAQMX9.5, the USB-6218 would show up in MAX and I was able to sue it
For some reason I am not able to fix this issue even if I uninstall/reinstall DAQMX.
Any recommendations?
Venu
(3,288 Views)
Open Device Manager and uninstall the "firmware loader" device. Then unplug/replug the DAQ.
That usually does the trick for me.
(3,275 Views)
