USB-6221 will not turn on
I went to take measurements today to find my system will no longer turn on.  Yes, it's plugged into the wall and to the computer via USB.  When I turn the System off and then back on to try to restart it, nothing happens.  No "Active" or "Ready" lights come on.
Any thoughts?
(2,915 Views)
Hi TP_651,
I would try the board on another system and verify that you are in fact receiving power from your wall outlet.  If the 6221 does not work with a known working power source on a different computer, you should Contact NI to arrange for a repair.
-John P
John Passiak
(2,897 Views)
