USB 6225 Hidden Connectors
Under the lid of the USB-6225 are four dual-row connectors (2 50-pin and 2 34-pin) labeled P1, P2, J1, and J2. I can find nothing about them in the docs except a drawing of them in the fuse diagram. Are they available for user I/O? If so, what are the pinouts?
Thanks.
(3,480 Views)
Hi ClausB,
The information about the connectors under the lid can be found in the USB-6225 OEM User Guide (p 7). However, those are the same terminals that you can access through the screw terminal of the USB-6225, you won’t be accessing any I/O that cannot be accessed though the screw terminal. I hope this is helpful,
Ana P
(3,435 Views)
Thanks, Ana.
Claus
(3,419 Views)
It seems that Bank 0 and Bank 1 of these connectors are swapped.
(3,312 Views)
