USB-6251 BNC Wiring Problem with Analog Input / Drifting Voltage
Hi everyone,
im trying to measure an analog voltage from a sensor with a USB-6251 BNC DAQ Board.
When measuring the signal in LabVIEW Signal Express the voltage is slowly increasing over time (=voltage drift?), so I think my wiring is probably wrong.
I attached the current wiring. The 5V Sensor is connected to a coupler which is then connected to a 24V power supply. The sensors ground is connected to the ground of the power supply (according to the data sheet), so I chose "Ground Ref. Signal" on the USB-6251 and used "Differential" Measurement.
Is there anything wrong with the wiring? Do I need to connect the grounds of the Power Supply and the DAQ? Both are connected to the same socket.
(2,674 Views)
Did you manage to solve this problem? According to what you described below, I was not able so far to identify the issue, but maybe you have some more hints in the meantime 🙂
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,554 Views)
