USB-6251 and Borland Delphi 7
i'm not shure if this is the right board to ask this question, but i will try:
I'm using Borland Delphi 7 and I have to communicate with the USB-6251. Is there any Delphi support for this device or can anybody guide me trough the steps needed to get this device working with Delphi 7?
Is there a Component available for easy communication? Please help me with this problem
Thanks in advance.
Markus
(4,017 Views)
maybe this link helps you get started:
http://digital.ni.com/public.nsf/allkb/A6715AA42405ACD786256F0A00633B8F
Check back, if you have any further questions.
Remember Cunningham's Law
(3,995 Views)
thanks for your answer. I have seen this link before. But I don't know what to do. I've seen there are delphi files. But how do I use them?
Has anybody a working example for configuring the device (if needed) and do one-shot measuring with 1 analog channel (+/-10V)? Or can anybody tell me in detail, what I have to do?
Is there a special configuration needed for the USB-6251? And how can I select the channel?
I'm using Windows Vista x64.
Thanks!
Markus
(3,982 Views)
It appears that not many people have done, what you want to do. Accordingly you will have to figure out much on your own.
Here are some more links from the NI website:
http://digital.ni.com/public.nsf/allkb/6DA2B77222315EE08525644B0077C1CA
http://digital.ni.com/public.nsf/allkb/B09727F89DA3A06C86256F430071D88E?OpenDocument
(3,978 Views)
