USB-6259-OEM
This is myu first experience with NI products and I'm going to make damned sure it will be the last. However, having coughed up a substantial amount of money, I'm stuck with the *expletive deleted* object and have to make it work.
It would have cost less time and money to design my own DAC interface and I damn well wish I had.
Can anyone help me?  If I want to communicate with the board, my only choice is to download DAQmx software (890MB) which then expands to add a further 947MB and then installs about 900MB further unwanted junk on my machine.  I have done this on a laptop but not on my desktop PC.  I'd hoped to use the laptop to identify the minimum necessary files.
I have tried extracting the drivers using DriverMax but these aren't complete and require a binary file, which I guess is some sort of firmware.  But the .bin name in the .inf file isn't one that's been installed on the laptop (which works).  On the desktop PC, a sample app reports that a .dll failed to initialise.  But it's a MS .dll, not an NI one!  Arrrgh!!
I don't want to dump 2.6GB on my customer's PC and really only want the software necessary to run my user program.  Surely this amounts to a fistful of .dll's, .exe's .bin's and .sys's but despite my careful efforts, I can't get to the essense of what is required.  Obviously, I can strip out the installation files afterwards but it's still nearly a GB of useless rubbish.
Richard.
(2,887 Views)
Smaller run-time versions of DAQmx are available.
(2,880 Views)
Thank you for the helpful pointer, Dennis.  I have downloaded the file and installed it.  It works fine and only 200MB which is still a lot but nevertheless a lot more acceptable to my customer.
- Richard.
(2,874 Views)
