USB 6343 digital output low
I am using the digital output of USB 6343.
Sometimes When I stop the writing(erasing the task) the output pin remains in high state(I see it in the oscilloscope).
Is there a possibility to define that after earasing the task the ouput pin will always be in the low state?
Leonid
(3,217 Views)
Leonid,
When you stop or clear a DAQmx task, the digital output lines will remain in whatever state they were in before stop/clear was called.  If it is important for the lines to end in the low state, I would recommend that you explicitly write them to low before clearing your task.  There is not a way to specify this behavior with clear task.
If you are doing a continuous generation and do not know the state of your port when you stop, I'd recommend running a 2nd 'on demand' task which writes the port low after you clear your hardware timed task.
Hope that helps,
Dan
(3,213 Views)
Accepted by topic author Leonid_Pascar
(3,205 Views)
